Visible Property
The Visible property indicates whether the touch screen keyboard is visible or not.
SiteKiosk.Keyboard.Visible [=bool]
Boolean value that specifies or retrieves the visibility status of the touch screen keyboard.
In order to be able to use this property, you must have configured a touch screen keyboard.
The following example reads the visibility status and shows it in an alert window.
alert(SiteKiosk.Keyboard.Visible);
