Duration Property
The Duration property contains the duration of the last session.
    [long=] SiteKiosk.Plugins("SiteCash").LastSessionInfo.Duration
    Long value that retrieves the duration.
    The following example shows the duration of the last session in an alert window.
    alert(SiteKiosk.Plugins("SiteCash").LastSessionInfo.Duration);
