Valid Property
The Valid property indicates if a last session exists.
    [bool=] SiteKiosk.Plugins("SiteCash").LastSessionInfo.Valid
    Boolean value that retrieves the valid status.
    The following example shows the valid status in an alert window.
    alert(SiteKiosk.Plugins("SiteCash").LastSessionInfo.Valid);
