LoadString Method
The LoadString method loads a string from the stringtable.
    [str=] SiteCafe.LocaleManager.LoadString(stringID)
    stringID Long value that specifies the string ID.
    Returns a String that contains the loaded string.
    The following example displays the first string of the stringtable.
    alert(SiteCafe.LocaleManager.LoadString(1));
