OnLanguageChanged Event
Fires when the language changed.
SiteCafe.LocaleManager.OnLanguageChanged = handler
The following example shows an alert window when the language changed.
SiteCafe.LocaleManager.OnLanguageChanged = OnLanguageChanged;
function OnLanguageChanged()
alert("The language changed");
