Enabled Property
The Enabled property indicates whether logging is enabled.
[bool=] SiteKiosk.Logfile.Enabled
Boolean value that retrieves the logging status.
The following example determines whether logging is enabled and displays it in an alert window.
alert(SiteKiosk.Logfile.Enabled);
