FileName Property
The FileName property contains the full path of the current logfile.
    [string=] SiteKiosk.Logfile.FileName
    String that retrieves the full path.
    The following example shows the full path of the current logfile in an alert window.
    alert(SiteKiosk.Logfile.FileName);
