Notification Method
The Notification method adds a notification entry to the log file.
    SiteKiosk.Logfile.Notification(msg)
    msg String that specifies the notification message.
    The following example adds a notification message to the SiteKiosk log file.
    SiteKiosk.Logfile.Notification('This is a notification.');
