OnMessage Event
Fires when a log file entry is added.
SiteKiosk.Logfile.OnMessage = handler
sequenceno |
Long value that contains the ID. |
time |
Date value that contains the time. |
utcoffset |
Long value that contains the utc offset. |
awtype |
Long value that contains the type. |
awlevel |
String value that contains the level. |
facility |
String value that contains the facility. |
text |
String value that contains the text. |
See the LogMessage object for further information about the parameters.
Use the DateTimeFormatter object to format the date.
The following example shows information about every log file entry.
<div id="id_log"></div>
SiteKiosk.Logfile.OnMessage = OnMessage;
function OnMessage(seq, time, utcoff, awtype, awlevel, facility, text)
id_log.innerHTML = "SequenceNo: " + seq +
" Time: " + time +
" UTC offset: " + utcoff +
" awtype: " + awtype +
" awlevel: " + awlevel +
" facility: " + facility +
" text: " + text;
