Warning Method
The Warning method adds a warning entry to the log file.
    SiteKiosk.Logfile.Warning(msg)
    msg String that specifies the warning message.
    The following example adds a warning message to the SiteKiosk log file.
    SiteKiosk.Logfile.Warning('This is a warning.');
