Write Method
The Write method writes a text to the logfile.
SiteKiosk.Logfile.Write(type, level, facility, text)
type |
Short value that specifies the type. |
level |
Short value that specifies the level. |
facility |
String that specifies the facility. |
text |
String that specifies the text to write. |
See the LogMessage object for further information about the parameters.
The following example writes a text to the SiteKiosk log file.
SiteKiosk.Logfile.Write(9999, 20, "Custom", "Text to write");
