Log Method
The Log method creates a logfile entry.
    SiteCafe.Server.Logging.Log(function, level, category, message)
    function String that is free but should specify the name of the caller function (for debugging).
    level Long value that specifies the level.
    category Long value that specifies the category.
    message String that specifies the message to write.
    Possible levels are:
    0 : ExtraDebug
    10 : Debug
    20 : Info
    30 : Warning
    40 : Error
    50 : FatalError
    Possible categories are:
    1 : General
    2 : Network
    3 : Database
    4 : FileIO
    The following example writes a warning message to the logfile.
    SiteCafe.Server.Logging.Log("function", 30, 0, "Warning msg");
