Facility Property
The Facility property contains the description of the device, plugin or component.
    [str=] SiteKiosk.Logfile.LastMessages.Item(index).Facility
    String that retrieves the facility.
    The following example shows the facility of the first message in an alert window.
    alert(SiteKiosk.Logfile.LastMessages.Item(1).Facility);
