Text Property
The Text property contains the text of the logfile message.
    [str=] SiteKiosk.Logfile.LastMessages.Item(index).Text
    String that retrieves the text.
    The following example shows the text of the first message in an alert window.
    alert(SiteKiosk.Logfile.LastMessages.Item(1).Text);
