UtcOffset Property
The UtcOffset property contains the difference between the current timezone and UTC in minutes.
[long=] SiteKiosk.Logfile.LastMessages.Item(index).UtcOffset
Long value that retrieves the utc offset.
The following example shows the utc offset of the first message in an alert window.
alert(SiteKiosk.Logfile.LastMessages.Item(1).UtcOffset);
