CheckInternetConnection Method
The CheckInternetConnection method checks and returns whether an internet connection exists.
SiteKiosk.Network.CheckInternetConnection(server)
server |
String containing the name of the server to reach. |
This methods causes an script error if no connnection exists. Use try / catch.
The server parameter should only contain the hostname without a protocol.
The following example pings the host 'www.google.com' to check for an internet connection.
var server = "www.google.com";
SiteKiosk.Network.CheckInternetConnectionComplete = OnCheckInternetConnectionComplete;
SiteKiosk.Network.CheckInternetConnection(server);
function OnCheckInternetConnectionComplete(ab_Status, al_ErrorCode)
alert(ab_Status);
