CheckInternetConnectionComplete Event
Fires when the internet connection check has been completed.
SiteKiosk.Network.CheckInternetConnectionComplete = handler
status |
Boolean value that indicates whether a connection is available. |
errorcode |
Long value that contains the error code. |
The following example pings the host 'www.google.com' to check for an internet connection.
var server = "www.google.com";
SiteKiosk.Network.CheckInternetConnectionComplete = OnCheckInternetConnectionComplete;
SiteKiosk.Network.CheckInternetConnection(server);
function OnCheckInternetConnectionComplete(ab_Status, al_ErrorCode)
alert(ab_Status);
