DefaultPrinter Property
The DefaultPrinter property contains the name of the default printer.
    SiteKiosk.Printer.DefaultPrinter [=str]
    String that specifies or retrieves the name.
    The following example displays the name of the default printer.
    alert(SiteKiosk.Printer.DefaultPrinter);
