OnChangedJob Event
Fires when a print job property changed.
SiteKiosk.Printer.OnChangedJob = handler
printer |
PrinterInfo object that contains the parent printer of the changed job. |
job |
JobInfo object that contains the changed job. |
The following example displays the parent printer name and the ID of the changed job.
SiteKiosk.Printer.OnChangedJob = OnChangedJob;
function OnChangedJob(printer, job)
pName = printer.PrinterName;
jID = job.JobId;
alert("Job changed: " + jID + " of printer " + pName);
