OnChangedPrinter Event
Fires when a printer property changed.
    SiteKiosk.Printer.OnChangedPrinter = handler
    printer PrinterInfo object that contains the printer that changed.
    The following example displays the name of the printer that changed.
    SiteKiosk.Printer.OnChangedPrinter = OnChangedPrinter;
    function OnChangedPrinter(printer)
       alert("Printer changed: " + printer.PrinterName);
