OnDeletedJob Event
Fires when a print job has been deleted.
    SiteKiosk.Printer.OnDeletedJob = handler
    printer PrinterInfo object that contains the parent printer of the deleted job.
    job JobInfo object that contains the deleted job.
    The following example displays the parent printer name and the ID of the deleted job.
    SiteKiosk.Printer.OnDeletedJob = OnDeletedJob;
    function OnDeletedJob(printer, job)
       pName = printer.PrinterName;
       jID = job.JobId;
       alert("Job deleted: " + jID + " of printer " + pName);
