OnNewJob Event
Fires when a new print job has been created.
SiteKiosk.Printer.OnNewJob = handler
printer |
PrinterInfo object that contains the parent printer of the new job. |
job |
JobInfo object that contains the new job. |
The following example displays the parent printer name and the ID of the new job.
SiteKiosk.Printer.OnNewJob = OnNewJob;
function OnNewJob(printer, job)
pName = printer.PrinterName;
jID = job.JobId;
alert("New job: " + jID + " of printer " + pName);
