Comment Property
The Comment property contains a brief printer description.
[str=] SiteKiosk.Printer.Printers.Item(index).Comment
String that retrieves the description.
The following example displays a brief printer description of the first available printer.
alert(SiteKiosk.Printer.Printers.Item(1).Comment);
