Datatype Property
The Datatype property contains the name of the data type used to record a print job.
[str=] SiteKiosk.Printer.Printers.Item(index).Datatype
String that retrieves the name of the data type.
The following example displays the name of the data type of the first available printer.
alert(SiteKiosk.Printer.Printers.Item(1).Datatype);
