DefaultPriority Property
The DefaultPriority property contains the default priority value assigned to each print job.
[long=] SiteKiosk.Printer.Printers.Item(index).DefaultPriority
Long value that retrieves the default priority.
The following example displays the default priority value assigned to each print job of the first available printer.
alert(SiteKiosk.Printer.Printers.Item(1).DefaultPriority);
