GetJob Method
The GetJob method returns a print job by ID.
[obj=] SiteKiosk.Printer.Printers.Item(1).GetJob(ID)
ID |
Long value that specifies the job ID. |
Returns a JobInfo object that provides information about the job.
The following example receives a print job object by ID.
job1 = SiteKiosk.Printer.Printers.Item(1).Jobs.Item(1);
job2 = SiteKiosk.Printer.Printers.Item(1).GetJob(job1.JobId);
if (job1 == job2) alert("GetJob(ID) works.");
