Info Property
The Info property contains an information string with some values of this object.
    [str=] SiteKiosk.Printer.Printers.Item(index).Info
    String that retrieves the information.
    The following example displays the information string of the first available printer.
    alert(SiteKiosk.Printer.Printers.Item(1).Info);
