KeepPrinterPausedOnQuit Property
The KeepPrinterPausedOnQuit property indicates whether the pause status is kept when quitting.
[bool=] SiteKiosk.Printer.Printers.Item(index).KeepPrinterPausedOnQuit
The following example determines whether the pause status is kept when quitting for the first available printer and displays it in an alert window.
alert(SiteKiosk.Printer.Printers.Item(1).KeepPrinterPausedOnQuit);
