LimitJobCount Property
The LimitJobCount property indicates whether the number of simultaneous print jobs is limited.
    [bool=] SiteKiosk.Printer.Printers.Item(index).LimitJobCount
    This setting has been configured in the SiteKiosk Wizard.
    The following example displays the maximum number of simultaneous print jobs of the first available printer if there is a limit.
    if (SiteKiosk.Printer.Printers.Item(1).LimitJobCount)
    alert(SiteKiosk.Printer.Printers.Item(1).MaxJobs);
