LimitPageCount Property
The LimitPageCount property indicates whether the number of pages per print job is limited.
[bool=] SiteKiosk.Printer.Printers.Item(index).LimitPageCount
This setting has been configured in the SiteKiosk Wizard.
The following example displays the maximum number of pages per print job of the first available printer if there is a limit.
if (SiteKiosk.Printer.Printers.Item(1).LimitPageCount)
alert(SiteKiosk.Printer.Printers.Item(1).MaxPages);
