Location Property
The Location property contains the name of the physical printer location.
    [str=] SiteKiosk.Printer.Printers.Item(index).Location
    For example, the physical location name of a printer could be "Bldg. 38, Room 1164".
    The following example displays the name of the physical printer location of the first available printer.
    alert(SiteKiosk.Printer.Printers.Item(1).Location);
