MaxJobs Property
The MaxJobs property contains the maximum number of simultaneous print jobs.
    [long=] SiteKiosk.Printer.Printers.Item(index).MaxJobs
    Long value that retrieves the maximum number.
    This setting has been configured in the SiteKiosk Wizard.
    The following example displays the maximum number of simultaneous print jobs of the first available printer if there is a limit.
    if (SiteKiosk.Printer.Printers.Item(1).LimitJobCount)
    alert(SiteKiosk.Printer.Printers.Item(1).MaxJobs);
