MaxPages Property
The MaxPages property contains the maximum number of pages per print job.
[long=] SiteKiosk.Printer.Printers.Item(index).MaxPages
Long value that retrieves the maximum number.
This setting has been configured in the SiteKiosk Wizard.
The following example displays the maximum number of pages per print job of the first available printer if there is a limit.
if (SiteKiosk.Printer.Printers.Item(1).LimitPageCount)
alert(SiteKiosk.Printer.Printers.Item(1).MaxPages);
