Parameters Property
The Parameters property contains the default print-processor parameters.
    [str=] SiteKiosk.Printer.Printers.Item(index).Parameters
    String that retrieves the parameters.
Remarks Examples
    The following example displays the default print-processor parameters of the first available printer.
    alert(SiteKiosk.Printer.Printers.Item(1).Parameters);
