PortName Property
The PortName property contains the name(s) of the printer port(s) used to transmit data to the printer.
[str=] SiteKiosk.Printer.Printers.Item(index).PortName
String that retrieves the port name(s).
If a printer is connected to more than one port, the names of each port are separated by commas (for example, "LPT1:,LPT2:,LPT3:").
The following example displays the name(s) of the printer port(s) of the first available printer.
alert(SiteKiosk.Printer.Printers.Item(1).PortName);
