PrintProcessor Property
The PrintProcessor property contains the name of the print processor used by the printer.
[str=] SiteKiosk.Printer.Printers.Item(index).PrintProcessor
String that retrieves the print processor name.
The following example displays the name of the print processor used by the first available printer.
alert(SiteKiosk.Printer.Printers.Item(1).PrintProcessor);
