Priority Property
The Priority property contains the priority value used by the spooler to route print jobs.
[long=] SiteKiosk.Printer.Printers.Item(index).Priority
Long value that retrieves the priority.
The following example displays the priority value used by the spooler to route print jobs of the first available printer.
alert(SiteKiosk.Printer.Printers.Item(1).Priority);
