SepFile Property
The SepFile property contains the name of the file used to create the separator page.
[str=] SiteKiosk.Printer.Printers.Item(index).SepFile
String that retrieves the file name.
The separator page is used to separate print jobs sent to the printer.
The following example displays the name of the file used to create the separator page of the first available printer.
alert(SiteKiosk.Printer.Printers.Item(1).SepFile);
