ServerName Property
The ServerName property contains the name of the server controlling the printer.
    [str=] SiteKiosk.Printer.Printers.Item(index).ServerName
    String that retrieves the server name.
    If this string is NULL, the printer is controlled locally.
    The following example displays the name of the server controlling the first available printer.
    alert(SiteKiosk.Printer.Printers.Item(1).ServerName);
