ShowPrinterInDialog Property
The ShowPrinterInDialog property indicates whether to show the printer in the SiteKiosk print dialog.
[bool=] SiteKiosk.Printer.Printers.Item(index).ShowPrinterInDialog
This setting has been configured in the SiteKiosk Wizard.
The following example determines whether to show the first available printer in the SiteKiosk print dialog.
alert(SiteKiosk.Printer.Printers.Item(1).ShowPrinterInDialog);
