UntilTime Property
The UntilTime property contains the latest time at which the printer will print a job.
    [long=] SiteKiosk.Printer.Printers.Item(index).UntilTime
    Long value that retrieves the time.
    This value is expressed as minutes elapsed since 12:00 AM GMT (Greenwich Mean Time).
    The following example displays the latest time at which the first available printer will print a job.
    alert(SiteKiosk.Printer.Printers.Item(1).UntilTime);
