Count Property
The Count property contains the number of available printers.
[long=] SiteKiosk.Printer.Printers.Count
Long value that retrieves the number of printers.
This is the same value as returned by the Printer.ManagedPrinterCount property.
This property is 0 if Printer Monitoring has not been enabled in the SiteKiosk configuration.
The following example shows the number of available printers in an alert window.
alert(SiteKiosk.Printer.Printers.Count);
