IsResetAccount Property
The IsResetAccount property indicates whether the reset function has been enabled in the configuration.
[bool=] SiteKiosk.Plugins("SiteCash").RuntimeMenuSettings.IsResetAccount
The following example determines whether the reset function is enabled and shows it in an alert window.
var RMSettings = SiteKiosk.Plugins("SiteCash").RuntimeMenuSettings;
alert(RMSettings.IsResetAccount);
