AddDispatch Method
The AddDispatch method adds a member to the SiteCash script.
    SiteKiosk.Plugins("SiteCash").Script.AddDispatch(newname, dispatch)
    newname String that specifies the new name of the added member.
    dispatch Dispatch to add.
    Script.Start() function must be called after Script.AddDispatch() has been used.
    The following example adds a property to the SiteCash script.
    var newobj = new Object();
    newobj.newprop = "New property";
    SiteKiosk.Plugins("SiteCash").Script.AddDispatch("newobj", newobj);
    SiteKiosk.Plugins("SiteCash").Script.Start("c:/scriptfile.js");
    alert(SiteKiosk.Plugins("SiteCash").Script.Dispatch.newobj.newprop);
