Filename Property
The Filename property contains the name of the SiteCash script file.
    [str=] SiteKiosk.Plugins("SiteCash").Script.Filename
    String that retrieves the file name.
    The following example shows the SiteCash script file name in an alert window.
    alert(SiteKiosk.Plugins("SiteCash").Script.Filename);
