Start Method
The Start method starts a choosen script.
    SiteKiosk.Plugins("SiteCash").Script.Start(filename)
    filename String that specifies the absolute script filename.
    A running script will be terminated when a new one is started.
    The following example starts a SiteCash script.
    SiteKiosk.Plugins("SiteCash").Script.Start("c:/file.js");
