AccountEnabled Property
The AccountEnabled property indicates if the script device account is currently enabled.
    SiteKiosk.Plugins("SiteCash").Devices("ScriptDevice").
    AccountEnabled [=bool]
    Boolean value that specifies or retrieves if the script
    The SiteKiosk Object Model can only access the script device account when it is enabled. If this property gets disabled, the script device credit will be subtracted from the account balance of the SiteCash object immediately.
    The following example determines if the script device account is currently enabled and shows it in an alert window.
    scash = SiteKiosk.Plugins("SiteCash").Devices("ScriptDevice");
    alert(scash.AccountEnabled);
