DeviceName Property
The DeviceName property contains the name of this device.
[str=] SiteKiosk.Plugins("SiteCash").Devices("ScriptDevice").DeviceName
The name of this device can be defined in the SiteKiosk configuration.
The following example shows the name of this device in an alert window.
scash = SiteKiosk.Plugins("SiteCash").Devices("ScriptDevice");
alert(scash.DeviceName);
