Testmode Property
The Testmode property indicates if the testmode of the script device is enabled.
[bool=] SiteKiosk.Plugins("SiteCash").Devices("ScriptDevice").Testmode
Boolean value that retrieves if the testmode is enabled.
The testmode allows to modify the accounts of the SiteCash and ScriptDevice objects without paying, it can be enabled in the SiteKiosk configuration. If enabled, a payment dialog is shown in SiteKiosk.
The following example determines if the testmode is enabled and shows it in an alert window.
scash = SiteKiosk.Plugins("SiteCash").Devices("ScriptDevice");
alert(scash.Testmode);
