Volatile Property
The Volatile property indicates if the balance can change spontaneously.
SiteKiosk.Plugins("SiteCash").Devices("ScriptDevice").Volatile [=bool]
Boolean value that specifies or retrieves the volatility status.
This property sets the work mode of the pull mode. If true, always the complete amount is demanded.
The following example determines the volatility status and shows it in an alert window.
alert(SiteKiosk.Plugins("SiteCash").Devices("ScriptDevice").Volatile);
